Re: Farmall B wide front???
Posted by Bill46 on June 25, 2008 at 05:11:32 from (65.112.42.83):
In Reply to: Re: Farmall B wide front??? posted by Dave_Id on June 24, 2008 at 15:48:49:
Must be an A wide front...or an A wide front with a C axle. The steering is on the wrong side for a C.
Almost bet it has an A box and C axle.
Intresting to say the least.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo ... [Read Article]
Latest Ad: Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use. [More Ads]
