Posted by Bob M on June 24, 2008 at 08:38:31 from (151.190.254.108):
In Reply to: Super H electrical posted by aaachris on June 24, 2008 at 07:36:12:
Like Jim points out below the 6 volt Super H does not use a resistor.
As to your points burning problem, also as Jim mentions the cause can be a bad condenser, bad coil (draws too much current) or oil contamination on the points.
Point contamination is easy to spot. To narrow it down between condenser and coil, observe the ammeter with the ign switch "on" and the engine stopped. If it reads more than 3 - 4 amps discharge the coil's drawing too much current and overloading the points. Otherwise suspect a bad condenser. (Just because both coil and condenser are new doesn't mean they're good out of the box - especially if they came from China!)
Today's Featured Article - History of the Cockshutt Tractor - by Danny Bowes (Dsl). The son of a very successful Toronto and Brantford, Ontario merchant, and himself quite an entreprenuer, James G. Cockshutt opened a business called the Brantford Plow Works in 1877. In 1882, the business was incorporated to become the Cockshutt Plow Company. Along with quality built equipment, expedious demand and expansion made Cockshutt Plow Works the leader in the tillage tools sector of the farm equipment industry by the 1920's.
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
