Tom Windsor said: (quoted from post at 21:08:44 06/16/08) That sure is flat country..I think I could probably get my airplane in there.
tw[/quote:7f006d1ef2]
Mostly rolling hills, but nothing too big. We are only a few miles from the highest point in ND and there are a couple of Buttes only a few miles away as well.
Fawteen said: (quoted from post at 01:03:43 06/17/08) I wouldn't have thought an H would handle that chisel plow as well as it did!
It wasn't real deep, just barely getting dirt over the sweeps... I hooked the 4450 to it later and was able to make that spin out! Had to kick in the MFWD to work it nice and deep.
[quote:7f006d1ef2="sd pete"](quoted from post at 04:40:18 06/17/08) That blew the cobwebs out of the old girl. Check with IHC it might still be under warranty.
I believe the warranty period ran out on this one about 66 years ago...
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
