Posted by HENRY E NC on June 12, 2008 at 19:48:40 from (216.119.6.210):
In Reply to: H Throttle posted by Frank Emmite on June 12, 2008 at 18:11:06:
First of all the box in front of the carb is actually called the governor . You can take the cover off of the governor. There is no oil that will come running out. Some times the weights hang up or if worn enough can hit the sides of the box and stay there.Take it apart and watch to see what happens. The tube that runs from the carb that actuates the butterfy in the carb could be hung up also. Nuff said Henry
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
