The bottom screw is where to enrich the fuel mixture for power. You probably have fuel blockage somewhere. Pull the gas line at the carb. and see if there's a full flow of gas. Catch the gas in a clean container. If the flow is good pull that tube fitting and check that screen that's been suggested. If it is clean you probably need to clean the carburetor thoroughly.
The coil can cause the engine to quit that's been suggested, but you need to check for fire to the plugs asap before the coil cools. Hal
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
