To find out how much you're off is to bring No1 piston to TDC on the compression stroke again. Your timing mark on the damper pulley should be aligned with pointer, then remove the mag's cap and then see where the rotor is pointing. It should be pointing to the No1 plug tower. If its off you will need to pull the mag and place the rotor at the No1 plug tower. Then see if it runs ok. Hal
Today's Featured Article - Tractor Profile: Silver King - by Staff. Silver King tractors were produced by the Fate-Root-Heath Company of Plymouth, Ohio. The company was founded by John Fate in 1884 and was originally called the "J.D. Fate Company". After several mergers over the years, the final company name of Fate-Root-Heath came about in 1919. The first tractor produced was actually called the "Plymouth" tractor and was powered by a 20 HP 4-cylinder engine with a 3x4" bore and stroke. The four speed transmission had a top speed of 25 mph! After more t
... [Read Article]
Latest Ad:
[More Ads]
