Cat does not use a compression check to diagnose engine problems. They recommend a leak down test. I made a leakdown tester from an air blowgun and 1/4" pipe fittings. Tee in a pressure gauge. Set the cyinder at TDC and put it in gear or lock the engine somehow. Pressurize the cylinder through the injector hole. I used the tip off of a gas compression gauge which fit on a 1/4" pipe nipple. You can easily hold it against 100 psi.
Use your compressor to presurize the cylinder to your max pressure. Shut off the air and see if it will hold. If air leaks try to locate where it is going. Intake or exaust manifold indicates valve. Into crankcase, piston or rings. Or into the dreaded cooling system may mean cracked head.
Today's Featured Article - The Rescue of a Fordson F - by Anthony West. Introduction I live in the UK and have for many years restored Fordson tractors (in the main model N's). I have also restored and shown model F's, E 27N's, Field Marshall Series 2, David Brown Cropmasters and the old rey Fergeson T 20. At one time I had seven restored examples which were shown and used in ploughing matches. As most restorers, I have a number of war stories I can relate on a range of topics that may help other like minded and interested people. Perhaps my first p
... [Read Article]
Latest Ad:
[More Ads]
