Wellsy - Even if the resistor has failed the generator should still charge hard with the light switch set to the "H" position.
Most likely the ammeter box cover - and thus the switch - is not grounding to the tractor frame. Another possibility (long-shot...) is the LHDB switch has failed.
Tip - If you run your tractor a lot replace the cutout and manual control with a voltage regulator! It'll solve your field grounding problem. Also it will do a better job keeping the battery charged (and not overcharging....) than you can ever do with the manual control.
Today's Featured Article - Tractor Profile: Silver King - by Staff. Silver King tractors were produced by the Fate-Root-Heath Company of Plymouth, Ohio. The company was founded by John Fate in 1884 and was originally called the "J.D. Fate Company". After several mergers over the years, the final company name of Fate-Root-Heath came about in 1919. The first tractor produced was actually called the "Plymouth" tractor and was powered by a 20 HP 4-cylinder engine with a 3x4" bore and stroke. The four speed transmission had a top speed of 25 mph! After more t
... [Read Article]
Latest Ad:
[More Ads]
