Posted by Bob M on May 22, 2008 at 12:53:43 from (151.190.254.108):
In Reply to: CUB WIRING posted by S/C BOB on May 22, 2008 at 09:53:06:
Gotta be either it's wired up wrong or the cutout relay in the voltage regulator has stuck closed.
First double and triple check your wiring - make sure all the connections are made to the proper terminals. Also make sure there are no accidental grounds. Pay particular attention to the wire between the voltage regulator BAT terminal and the ammeter. (Also if your Cub has lights check the supply wire to the light switch....)
If you find no errors or grounds, next temporarily disconnect the wire from the GEN terminal at the regulator. Now try reconnecting the wire at the ammeter. If you still get fireworks the problem is a bad voltage regulator - time for new one.
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
