$700? Is there a cheaper place to buy these? Because the cheapest Saginaw I've found is 1300 w/o cylinder and $900 w/o cylinder for a worksaver. The only cheaper one I've found is a hokey pokey Cross Mfg. unit, and it looks a bit pieced together and restricted in its travel.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
