Re: thank you for the response
Posted by RedJohn-2 on May 22, 2008 at 05:12:57 from (68.207.108.95):
In Reply to: thank you for the response posted by bgarrett on May 21, 2008 at 19:35:54:
barrett, I forgot to mention, you will have enough hydraulic HP to lift about any implement you plan to use. Expect to spend about $700.00.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
