Re: Engine block paint/sealer
Posted by Jim Becker on May 15, 2008 at 19:27:53 from (71.170.201.34):
In Reply to: Engine block paint/sealer posted by BOBM25 on May 12, 2008 at 12:25:57:
Unfortunately, even if you get the inside properly sealed now, oil that is already in the cast iron will continue to seep out for some time.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
