I have never seen the inside of the block, but there is a silver substance, almost like "Kool-Seal" on the outside where the weld was ground smooth. One day I plan to re-sleeve and install a piston kit, re-do the head, ect. It may not need these services, but before I paint it, I want to be finished working on it for a long time! When I drop the pan, I would like to seal from the inside with a cast iron sealant at the repair area. Also, what could I use on the outside to ensure a good, leak free seal?
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
