charles todd said: (quoted from post at 19:59:26 05/14/08) I am curious about this "crankcase sealer". At one time my F504D threw a rod and knocked two holes in the block. These were welded well and some type of sealer was used (seems to be silver), it weeps just enough to annoy me and keep the block oily/dirty, but not enough to call it a leak... I would like to repair this, kinda hard to plan a repaint as is. Help!
Charles
I don't know if you meant they put it on the inside or outside of the block, but sealer is supposed to be used on the inside, from what little I know about it. I doubt if you want to disassemble the engine, but that probably is the only way to fix it. Seems like it should have been welded on the inside, also.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
