the coupling is just a steel disc with two slots 90 degrees apart. rotate the pump coupling so one is facing up and down, the pump will just slide straight down. BE CAREFUL, that dang pump is HEAVY!!! i use all thread rod in four of the retaining bolts, run a nut up on each, then remove the rest of the bolts, use the nuts to lower the pump down, it takes a while, but better than droppin that pump on ya!!!!!
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
