Posted by chadd on April 28, 2008 at 16:22:27 from (155.92.31.167):
In Reply to: Tractor rides. M.P.G. posted by RustyFarmall on April 28, 2008 at 12:34:19:
According to the Nebraska Test data I've seen, an M consumes approximately 1.2 gallons/hr under no load at 1450 rpm and around 3 gallons per hour under full load at 1450 rpm. An H burns 2.2 gallons per hour under full load at 1650 rpm and 0.9 gallons per hour under no load at 1650 rpm. So, if your driving at WOT in road gear, you are likely burning at least 1 gallon per hour with either tractor. Now, when you are idling along at half throttle or less, your fuel consumption is likely much lower.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
