Posted by CNKS on April 24, 2008 at 17:25:50 from (216.144.104.128):
In Reply to: Farmall IH 300 posted by Tom Price on April 24, 2008 at 17:10:46:
Provided you have the float set correctly, it is a flow problem. You could have a restriction in the tank outlet. Take a flashlight and a wire, remove the gas cap and poke the wire through the outlet. It is possible, not likely that the vent in the gas cap is plugged, try it with the cap removed. There is a screen attached to the fitting that the gas line screws into. If you did not remove that fitting when you cleaned the carb, you did not see it. Otherwise you have a plugged jet. Did you soak the whole carb in carb cleaner when you had it off?
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
