Re: farmall 140 will not start
Posted by Dewey Brown on April 23, 2008 at 09:08:28 from (204.111.105.117):
In Reply to: Re: farmall 140 will not start posted by ih560 on April 23, 2008 at 08:56:05:
Yes, it's drawing lots of amps and the starter will not turn.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
