If the shaft does not have play, the bearing is likely OK. I think some whine would be normal. If it is very loud, it may be the gear or the bearing. There are two bearings on the belt pulley shaft. The one nearest the pulley will come out once the bearing retainer cap/seal holder is off but it may be hard to get it to come out. I don't know if it is pressed in there or not. To get the other bearing out, you will have to remove the shaft which requires removing the pressed in plug that is in the housing on the side opposite the pulley. I'd try adjusting the gear lash before I messed with the bearings unless you have shaft play. You need to get a manual that tells you how to adjust the gear lash.
Today's Featured Article - The Rescue of a Fordson F - by Anthony West. Introduction I live in the UK and have for many years restored Fordson tractors (in the main model N's). I have also restored and shown model F's, E 27N's, Field Marshall Series 2, David Brown Cropmasters and the old rey Fergeson T 20. At one time I had seven restored examples which were shown and used in ploughing matches. As most restorers, I have a number of war stories I can relate on a range of topics that may help other like minded and interested people. Perhaps my first p
... [Read Article]
Latest Ad:
[More Ads]
