I know that my 450 Diesel would not start on gas when the starting lever wasn't all the way back. For a short time, it wouldn't lock to the gas side so I was tying it back with a wire. It wasn't quite far enough and the engine refused to start.
Now, that starting lever moves a long rod that is adjustable. Try incrementally adjusting it and see what happens.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
