Just got in the house from working on the MD, removed the intake and adjusted all the starting mechinism. It was out quite a bit. still no luck though, although my battery was getting weak, and I have old plugs in. New set will be here tuesday. Maybe that will help too. The tractor is ALWAYS so close to starting, just seems like it doesn't have just quite enough oommph to stay running, almost like a motor with to low of compression.. Starting to get frusterated!!!
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
