I have an MD that never started worth a crap on gas until I got an I&T manual and adjusted the starting linkage to spec. Since then, starts like a dream. Can't tell you what the number or price of the manual is, since it's not in front of me, but it sure made a huge difference, and was well worth the money. If you're getting much smoke while trying to start it, that indicates, to me, that you're getting some diesel in there with the gas, and a linkage adjustment should cure this. SMD and later Operator's manuals may have the procedure in them as well, but I'm sure the I&T does. First time through took me a few hours, but it was well worth the effort. Good luck, and let us know how it turns out.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
