Posted by Owen Aaland on April 17, 2008 at 20:40:19 from (65.165.246.73):
In Reply to: 2606 brake balls posted by bc on April 17, 2008 at 06:41:26:
As you pull on the actuating rod the links pull on the actuator plate to apply the brakes. The way the brakes are designed they apply the most force when the actuator just starts to move. As you pull farther out on the rod the angle of the link changes so that they will no longer apply as much force as they continue to move. Adding washers may give you a hard pedal but you will not have much braking action.
You have four surfaces that wear in addition to the disks. You need to remove enough material from the mating surface from the cover to compensate for all the wear. On 560s I have removed .125 to get good braking action.
It sure would be nice if someone were to manufacture disks with thicker lining to compensate for the wear.
Today's Featured Article - Tractor Profile: Silver King - by Staff. Silver King tractors were produced by the Fate-Root-Heath Company of Plymouth, Ohio. The company was founded by John Fate in 1884 and was originally called the "J.D. Fate Company". After several mergers over the years, the final company name of Fate-Root-Heath came about in 1919. The first tractor produced was actually called the "Plymouth" tractor and was powered by a 20 HP 4-cylinder engine with a 3x4" bore and stroke. The four speed transmission had a top speed of 25 mph! After more t
... [Read Article]
Latest Ad:
[More Ads]
