Posted by Bill Lisbon on April 15, 2008 at 19:07:16 from (69.89.162.236):
In Reply to: Hydralic oil on H posted by Booth2563 on April 15, 2008 at 17:53:36:
What kind of oil is leaking, if it's engine oil, the rear engine seal is leaking, if it's gear oil the front transmission seal is leaking. If it's hydraulic oil the hydraulic pump is leaking.The hydraulic pump is removed by taking all the pipes and fittings off, Remove control handle. Take down small plate and remove coupling. Slip a piece of pipe through the bottom of hyd. assy. have someone help hold it up until you remove bolts, then drop pump. you can check all your seals with pump out of the way.
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
