SamC-VT said: (quoted from post at 17:08:41 04/04/08) I see this advice here often, and almost always with considerable emphasis on "exactly" following directions. Is that because a shortcuts yield little improvement or because there is potential for making things considerably worse by not doing it "exactly"?
(My 560 clutch/TA needs adjustment, too)
If you don't do it EXACTLY, you will have trouble shifting gears OR you will be causing wear on a throwout bearing, clutch facing, etc.
The clearances inside there are not very big, and things need to work just right.
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
