I'd for dang sure ensure it's a SMTA before giving that kinda money. I'd check the SN on the plate. If the plate is gone I'd be suspect. Check the casting codes on the belly of the machine. I'm not sure what the codes are off the top of my head but there are casting differences between the later 400's/450's and the SMTA's. Make sure you aren't buying a homemade SMTA. I've been hearing about some of them popping up out there. It might be exactly like you say but you better be sure it is before giving $2k for a machine that's only worth a couple hundred if it turns out to be a phony.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
