Thanks for all the replies guys. I was thinking the same thing as most of you on it. The tractor would be bought and kept and more than likely restored. The steel that are on it are probably made up ones, as it is onwed by an amishman and around here they usually make up their own steel for their tractors. If we can strike a deal should be a good addition to the other M's and H's we have.
Again thanks for the replies and you comfirmed what I was allready thinking. Just wanted to see if my thinking was inline or not.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
