Re: Is smoke normal on new engine?
Posted by Michael price on March 26, 2008 at 20:47:28 from (205.188.116.73):
In Reply to: Is smoke normal on new engine? posted by Michael price on March 26, 2008 at 14:42:48:
In a parts catolog they had the rebuild kit and said that they were high compression pistons. I figured nobody made a low compression piston anymore.
The injector thats blowing bubbles would have low compression on the cylinder but I should have 2 good cylinders.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
