Run it for several hours, then let it sit overnight. Crack the oil pan drain plug. If it's getting coolant into a cylinder, some of it should find it's way into the oil. After sitting overnight, any little drop of coolant will have settled to the bottom and be easily visible. The other possibilty is low compression. Are you positive you got the correct pistons?
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
