Myself i do not mess with pumps , I pull them off and run them over to a good friend that has a pump shop . He does not hammer me and if the pump need rebuilt it is done and if it need just a couple seals then that is done . IF you pull the pump off just make sure 100% sure that you are on TDC BEFORE ya pull the pump . Myself i always pull the valve cover to make sure that the #1 cyl. valves are closed and the timing pointer is set at #1 and since i hve the valve cover off when the pump goes back on i run the valves . Since valve adjustment is like wheel bearing and never checked or adjusted it is time.
Today's Featured Article - Tractor Profile: Silver King - by Staff. Silver King tractors were produced by the Fate-Root-Heath Company of Plymouth, Ohio. The company was founded by John Fate in 1884 and was originally called the "J.D. Fate Company". After several mergers over the years, the final company name of Fate-Root-Heath came about in 1919. The first tractor produced was actually called the "Plymouth" tractor and was powered by a 20 HP 4-cylinder engine with a 3x4" bore and stroke. The four speed transmission had a top speed of 25 mph! After more t
... [Read Article]
Latest Ad:
[More Ads]
