Try taking off signal line on hyd pump, unscrew fitting and you will find a orfice-screen this needs to be removed to clean. If you have oil running out when you remove fitting chances are the orfice is clean. Also there is a signal check in priority remote that could broken worn/missing and there is a repair kit for this. There is 2 orfices in casting on hyd pump housing that can cause low or no pressure on these systems.If you have a local Case dealer that has online parts lookup you will find the location of these orfices. Good luck
Today's Featured Article - History of the Cockshutt Tractor - by Danny Bowes (Dsl). The son of a very successful Toronto and Brantford, Ontario merchant, and himself quite an entreprenuer, James G. Cockshutt opened a business called the Brantford Plow Works in 1877. In 1882, the business was incorporated to become the Cockshutt Plow Company. Along with quality built equipment, expedious demand and expansion made Cockshutt Plow Works the leader in the tillage tools sector of the farm equipment industry by the 1920's.
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
