jimmy Lawson said: (quoted from post at 16:58:51 03/09/08) Okay, finally dug out of the snow and back to the barn. I have 12 volts at the amp meter and at the battery side of the alternator. No voltage detected come out of the alternator to the resistor. No power at the coil either. Accidentally put the coil for "with resistor" and there is no resistor in the wiring, just on the alternator. Been reading on here about electronic ignition. Would this solve my troubles ?
The electronic ignition units (that is, their instructions) are emphatic that coil resistance is MORE important than in conventional circuits. So you do need the resistor or the true 12v (no resistor) coil. Second, without voltage to the coil terminal away from the distributor, it will NEVER start--period. Fix these things first before messing with anything else. It's always better to do a conversion on a running machine.
Today's Featured Article - Tractor Profile: Silver King - by Staff. Silver King tractors were produced by the Fate-Root-Heath Company of Plymouth, Ohio. The company was founded by John Fate in 1884 and was originally called the "J.D. Fate Company". After several mergers over the years, the final company name of Fate-Root-Heath came about in 1919. The first tractor produced was actually called the "Plymouth" tractor and was powered by a 20 HP 4-cylinder engine with a 3x4" bore and stroke. The four speed transmission had a top speed of 25 mph! After more t
... [Read Article]
Latest Ad:
[More Ads]
