Posted by El Toro on March 10, 2008 at 17:05:03 from (205.188.116.73):
In Reply to: 504 Farmall Gas posted by Booth2563 on March 10, 2008 at 14:48:08:
If I was buying it, I would want to hear it run. That engine doesn't have sleeves and if it needs an overhaul the block would probably need to be rebored oversize. What is he asking? Hal
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
