If you have good (unseated ) rings do this: Take it apart. Use a ball brush 250 grit glaze breaker on the cylinders. Use a slow drill and move at a brisk pace up and down the entire length of the bore (about 1 minute each) using 1/2 diesel, and 1/2 engine oil for solvent. Clean all parts, pre-lube the components with engine oil when putting it together. Make sure the rings are spaced at least 1/3 of the way around (staggered gaps). And go for it. JimN
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
