Since you have spark on all but #3, the problem is in the #3 terminal on the dist. cap. Could be the rotor isn't getting close enough to #3 terminal inside the cap. Is the cap firmly seated on the dist. housing? Have you measured the distance between the center terminal in the dist. cap & each of the individual terminals? Maybe #3 is slightly further away from the center than the other 3 & the spark can't jump the gap???
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
