As pale rider says why dont you just remove the #3 plug and replace it with one that you say fires wouldnt be the first time a bad plug showed up. I would have done that first cause of the other three fire that says a lot. I have found out a new plug out of the box dont always fire and i dont care what brand is either.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
