I forget if you have checked for continuity through the dist. cap with an ohmmeter. This would show up the possibility of no contact on the #3 terminal--even though you have changed dist. caps. Chances of getting a grounded {shorted] spark plug put in #3 as many times as you have had it in & out is probably not the problem. I'd start the engine & pull out the #3 wire from the dist. cap & put a bare wire in #3 & feel if you have a spark. If you hold on tightly, it won't bit too much.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
