I hesitate to mention this since it is so obvious that it is almost an insult to a person's intelligence, yet you did not mention it nor has anyone else up to this point. You claim that you have switched plug wires and tried a new cap and rotor yet the simplest and cheapest fix would be to simply swap locations with the plug that isn't firing with one that is and see if the problem follows the plug or remains with the location of the number 3 cylinder. Frankly I suspect you simply have a bad plug or perhaps installed a bad plug in a locaion where there was one before.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
