DO this test: With the ignition off and the cap removed, hook an ohmeter from the primary on the points to ground. Slowly rotate the engine two full revolutions and watch the ohmeter as each lobe opens the points. The ohmeter should go to zero (infinity) as each lobe opens the points. If it does not, the cylinder affected by that lobe will not fire.
Do this with all the plugs out so the engine will be easy to turn.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
