You've swapped out wires, so I'd guess that eliminates a ba wire. Have you checked for spark at the end of the wire, i.e., no plug?
Any sign of arcing on the new rotor tip or the contact in the cap for #3? It shouldn't have come up suddenly, but I'm wondering if wear on the rotor shaft or the bushing/bearings it rides in might be a factor.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
