Sounds like yu've done all you can electrically. Even if the block on the points wasn't greased and got crud under it, it whouldn't hve worn down the lobe for #3 any worse than the others.
Have you maybe got a valve stuck open that's flooding that cylinder making for a wet or fouled plug???
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
