While the diagnosis proceedure listed above is excellent, if you verify spark at all cylinders, then I would have to go with Gordo up there. Pull the valve cover (have a spare gasket handy) and check your push rods. If they are bent or slipped off the rocker arms, then you are not getting proper intake and exhaust into the cylinder, and it won't fire. When you run it a little and then pull the #3 plug, it should be wet from a lack of explosion. If you have spark (for sure) then I'd suspect the valve timing on #3 which is most likely due to the push rods having a problem. While you're in there, set ALL the valves to the spec clearances to prevent similar push rod failures in the future. Good luck! Dave
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
