Re: 656 Hydraulic Pressure Check
Posted by Allan In NE on February 23, 2008 at 10:44:42 from (148.78.243.24):
In Reply to: 656 Hydraulic Pressure Check posted by JerryF on February 23, 2008 at 09:42:44:
Jer,
Not trying to be a smart-mouth, but you replaced the right pump, didn't you? The front one?
How about that balance valve down there at your right boot heel. That isn't stuck or leaking across to the other side is it?
Sure sounds like it's going into full system pressure then losing it at a massive leak somewhere.
Does the hitch work normal in and of itself?
Allan
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
