Retcol: Wheel type changed near the end of M production. Before that all H or M rims were drop center, thus the center casting was smaller, clamps or lugs are different from the newer type. I expect those older rims and lugs were made by IH.
Beginning at SH-SM time all Farmall larger than the Super C were equipped with double bead rims and the center cast changed, bit larger diameter.
I've seen different clamps or lugs for the double bead rim type, and yes the outside supplier was the factor that made them different. Once manufacturers went to double bead rims the rims and lugs became standardized. I've used both Cockshutt and Deere rims on later Farmalls. The different outside suppliers is the reason for some differences, however the lugs for double bead rims will all interchange. You can even use a mix of several different types of lugs I've seen.
Today's Featured Article - Tractor Profile: Silver King - by Staff. Silver King tractors were produced by the Fate-Root-Heath Company of Plymouth, Ohio. The company was founded by John Fate in 1884 and was originally called the "J.D. Fate Company". After several mergers over the years, the final company name of Fate-Root-Heath came about in 1919. The first tractor produced was actually called the "Plymouth" tractor and was powered by a 20 HP 4-cylinder engine with a 3x4" bore and stroke. The four speed transmission had a top speed of 25 mph! After more t
... [Read Article]
Latest Ad:
[More Ads]
