Michael: I know how you feel, I always find this governor removal less than exciting. If you've never done it before, I recommend removing the radiator first. I have had to fix up the shaft bushing on the throttle lever input. Usually the output shaft is in good shape. I've never found much problem with the centrifical weights and the pivots. I always replace the spring that connects input and output shafts, unless the current one is in exceptional condition. I've never taken a gobernor apart and not replaced the thrust bearing. These two items are relatively inexpensive compared to the labor you put into getting to them.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
