Posted by tooltime on February 15, 2008 at 17:42:25 from (66.103.167.60):
i have a 340 Utility with a 12 volt conversion. I have timed this tractor a number of times, I put new points and set to .020, new plugs(autolites) and plug wires. new distributor cap/rotor. the coil was still the same 6 volt as was on the tractor before, i added a ballasr resistor from napa. Tractor starts right up, sounds great, but under load or if you drive it begins to miss a bit, i have checked fuel flow and carb. everything seems great. HERES where things get a bit weird for me. I started tractor , put my ear up close to ditributor and coil area, and thought i heard a little snapping noise. I shut the lights off in the shop, and to my surprize you could see little sparks coming from coil end where coil wire goes into coil, also noticed little blue color coming from each of the spark plug wires where rubber boot goes over spark plug.... what is going on here,Bad coil , maybe bad ballast resistor, im not sure what to do here... thanks for any ideas.
Today's Featured Article - Tractor Profile: Silver King - by Staff. Silver King tractors were produced by the Fate-Root-Heath Company of Plymouth, Ohio. The company was founded by John Fate in 1884 and was originally called the "J.D. Fate Company". After several mergers over the years, the final company name of Fate-Root-Heath came about in 1919. The first tractor produced was actually called the "Plymouth" tractor and was powered by a 20 HP 4-cylinder engine with a 3x4" bore and stroke. The four speed transmission had a top speed of 25 mph! After more t
... [Read Article]
Latest Ad:
[More Ads]
