the clearance you need is between the crank and the front steering/radiator support. i tried to attatch image with arrow and some coloring. measure all available space you have LxWxH. you should have no problems with hoses, it will be a pump and rigging a good support for it that might be a challenge--it needs to be fairly centered to the crank. the ford setup is nice there's a good hollow space where the IH is solid. there are enough makes of pumps out there that one might work for you after all. then you need to add a reservoir to the loader frame or on the tractor somewhere. that would be the least complicated way to supply oil to the loader. make sure if the loader is disconnected you hook the pump hoses in a loop so it doesn't build pressure or run dry, which means the engine needs to be off for that step.
Today's Featured Article - Tractor Profile: Silver King - by Staff. Silver King tractors were produced by the Fate-Root-Heath Company of Plymouth, Ohio. The company was founded by John Fate in 1884 and was originally called the "J.D. Fate Company". After several mergers over the years, the final company name of Fate-Root-Heath came about in 1919. The first tractor produced was actually called the "Plymouth" tractor and was powered by a 20 HP 4-cylinder engine with a 3x4" bore and stroke. The four speed transmission had a top speed of 25 mph! After more t
... [Read Article]
Latest Ad:
[More Ads]
