You say with the choke wide open, thats the way they should run. I'll take a guess here and figure you mean you have to have it choked all the way for it to run and if so it means you have a fuel flow problem. I would start by pulling the carb drain plug out and make sure you have a good steady flow of gas out of it for 5 plus minutes. Catch the gas so you can save it and also look at it to see if you have water in it. If you don't have a good flow there work back till you find where you loose the flow. If it flows good at the line but not the carb then you probably need to rebuild the carb
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
