Posted by ihc49er#2 on January 31, 2008 at 15:44:57 from (216.123.197.189):
In Reply to: cub oil pressure posted by oldiron29 on January 31, 2008 at 14:53:34:
i have a hard time beleiving the oil has to take the blame for this.seams to me like a mechanical problem,probably in the heart of the machine like oil pump clearances,relief valve?pick up tube? straight grade oils are getting obsolete.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
