The purpose of the sump check valve is to allow the steering hand pump to draw oil through it to prime the system if the MCV pump should fail and the steering system loose it's prime. If the sump check valve should fail then you will loose the MCV hydraulic system.
If you want to remove the plug you can push it out from the back side. The hole just goes through the housing to the reservoir.
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
